Dark Seas M1008 Project
19,163
Photos of the case broken down and what I found on the magnet.
Photos after cleaning the case a couple days before (before teardown):
Before:
After:
And yes my fiancé convinced me we needed a new puppy. That's Willow. She likes to help. 4 month old dutch shepherd.
Wow. What a difference it made - cleaning up the TC.
Looks like Willow was worn out. From all that helping :)
The parts look pretty good. I would look closely at the chain - making sure it wasn't stretched with the washer flying around inside.
DarkSeas
273
Leland, N.C.
Yeah man I'm really happy I took the time to get it right, I'm super proud to share how the case turned out after like 4 hours of scrubbing with brillo pads and some dawn.
Willow is definitely my little helper out on the tailgate. Just gotta remind her sometimes that brake clean will never taste good, no matter how exciting the can hiss sounds are. At least she can't speak english so she can't learn to repeat what I say at the truck back to her mom! rofl:beer:
19,163
Yep. For Sure!
DarkSeas
273
Leland, N.C.
Borrowing a seal driver set today/tomorrow to drive some seals into the transfercase and put it back together. Bearings are in. Replaced all 120 needle bearings on the driven shaft, wasn't too bad.
Plan is to get the truck back together and drive her outta there within a month. Some stuff came up and she's gotta move.
Only issue I see is I've got a rotten inner-passenger fender and two sketchy battery setups. I can get an inner fender for around $45 off LMC, JEGS, Holley, Summit, etc. A ratchet strap might do in a pinch, but sourcing a battery tray that could fit on a fender replacement is proving difficult. Anybody else deal with this?
Above: TM 20P for battery trays.
Below: All I can find are LH and RH versions of this, or used battery trays on ebay for like $130-250 a pop.
adf5565
632
Tioga, PA
Are you missing the original battery trays? Hillbilly Wizard sells replacement ones if so and they come with the hold-downs as well.
Replacement fender liners are still the same shape as original so the battery trays will fit fine. All you'll have to do is drill a couple new holes in the fender liner (as they aren't pre-drilled) for the bottom bolts that mount to them. I went with LMC as shipping seemed reasonable.
DarkSeas
273
Leland, N.C.
I've got the original rear but it's in rough shape. I saw HBW had a front tray but I was gonna try and find a cheaper temporary alternative before I go spending $150+ on a used OEM replacement. At the moment the front tray would be useless until I replace that inner fender, the current one would give the front tray nothing to stand on haha
DarkSeas
273
Leland, N.C.
Little update,
After a few words and a few hours I got the transfercase back on the CUCV. Tonight I plan on going back to finish bolting it up, putting the driveshafts in, and filling up the case and PS pump. Looking to move the truck out this week over to my place by Saturday, not really sure how the brakes are or the wipers, and it's gonna be a rainy week. Pray for me. -- pretty sure the brakes are okay, the guy that sold me the truck drove it to the garage. Should make a 10 minute drive to my house, and I'll get someone to follow me home in my truck in case the brakes go out or I break down or something.
I'll take and post some pictures tonight.
DarkSeas
273
Leland, N.C.
Here's the photos promised: bolted down the transfercase and put the rear driveshaft on tonight. Under the hood you can see I found a makeshift way to hold the batteries down to get home. Buddy of mine has two inner front fenders for sale, gonna probably get those and put em in at home before I really get the batteries good.
Cheers.
Next steps are to tap the threads on the front shaft flange (one hole wouldnt accept a bolt but the other 3 were smooth as butter). Front shaft on, fill my fluids in the PS pump, trans, and transfercase. Will do all that tomorrow. Looks like sunny weather maybe Saturday, I'll get her out the garage on her own power, clean up the garage, and wait for a couple hours of sun to drive home.
Also fixed the hood latch cable that was all frayed, just a little quality of life improvement. Not sure if I mentioned that earlier, I'm beat.
