FU1
e_beauregard
15
Louisiana, USA
Recently purchased an MEP803A (2002 model) and realized the FU1 fuse was missing. After digging through the front compartment I found it, intact, inside it’s cap/plug. Has anybody upgraded the fuse holder to something more secure? I found one online but not sure if it would work. Thanks in advice
Ray70
5,219
West greenwich/RI
You can upgrade it to anything you'd like, its 2 simple solder connections on the back, however the holder that's there now should be plenty secure enough.
You have to push in and turn it to remove the cap and when a fuse is in place the spring puts plenty of pressure on it to prevent accidental disengagement.
I'm sure many of us have received these sets ( myself included ) with the F1 cap rolling around inside, but I believe they were removed intentionally prior to the military disposing of them. Most of the ones I found with F1 sitting in the bottom of the control panel also had the fluids and filters removed, occasionally the hoses were also disconnected.
Guyfang
22,537
Burgkunstadt, Germany
The cap can come off the metal fuse holder insert. But a dab of glue and that fixes that. Continue to look in the control cube, and there is no telling what you may find. I think my record was 3 or 4 FU1 caps.
e_beauregard
15
Louisiana, USA
That would explain why no matter how much I press & twist, it just won't stick; the insert is free spinning inside the cap. I'll glue it this evening.
