birddog1106
- 10
- 3
- southport,nc
I have no power (24) to power switch checked fuel level-fuses will turn over on battle switch ??
I got the power back with a LARGE HAMMER !! low fuel switch Hanging-up Installed new fuel pump 3181 I think was the number.Tks for your response VGI assume you E-stop switch is pulled out and the CB-1 circuit breaker is pushed in?
If you have nothing at all, no panel lights nothing, check the shunt mounted near the right side, bottom inside the control box.
Also check the CR1 diode, I think it's 2nd up from the bottom on the panel to the rear left back wall of the control cube, below the 4 burden resistors, R10 - R R-13.
If either is open you will have nothing for DC power at the control panel.
AS Before,I had NO Power at on/off (red) button. dash lights did not come on untill that 5 lb did it`s job. Also the fuel pump E-8131 works great and easy installation. No fault light.............vgOk, so that would mean that you had 24V DC at the panel, you just couldn't start it because the low fuel fault should have been illuminated.
Were you getting a fault light when trying to start it?
Also, in a low fuel scenario typically the machine would start briefly then shut down within a few seconds with the fault indicator on.
Also a bad fuel pump would not cause "no power either", so I assume you had power, it just wouldn't start??
Well we all have opinions and thank you for Yours..............VGIn that case you hammer action had to have done something else to "fix" a bad connection somewhere.
The fuel level sensor has absolutely no ability to disconnect 24V power from the control panel, so I think you just got lucky, but perhaps only temporary.
Ray,Just got a 802 and it`s not charging the batterys.Had it ( alternator ) checked and was told working.Reinstalled and still not charging battery`s.Batt. guage on dash in Red ! Checked FS1 fuse it`s good Terminal in center of regulator showing 19+ volts any Idea`s................TUWell we all have opinions and thank you for Yours..............VG
.Ray,Just got a 802 and it`s not charging the batterys.Had it ( alternator ) checked and was told working.Reinstalled and still not charging battery`s.Batt. guage on dash in Red ! Checked FS1 fuse it`s good Terminal in center of regulator showing 19+ volts any Idea`s................TU
Yes Engine starts great/Powers up but battery voltage stays the same 12+ volts..
Guessing that you checked the battery? It has electrolyte? At the proper level? How does the battery read with a multi-meter?
Ray thanks for the reply.........I used a 10 lb Hammer nah just jokeing..Found the FS 1 fuse holder bad so I went to NAPA and got a 20 amp in line fuse holder and that guage on control panel went to 30 amps !! went I srarted it. I checked one battery (voltage) and I was at 14+ so Problem Solved. Again TU VGIf the alternator isn't working your batteries should be slowly depleting while you're running. Are you having to charge the batteries with an external charger to be able to start it after it has run a while?
Rather than testing at the regulator, with the engine running, test at the Batt+ post , the slave port or at the starter wires and see if you still only get 19V.
You can also remove any 1 battery wire while its running, the machine will shut off if the alternator is doing nothing at all and it will stay running if the alternator is at least working somewhat.
Yes,Please Delete.................TUSo if the problem is solved, what about your other post looking for the fuse holder? Is it still a viable thread? Or can it be deleted?
