- 1,549
- 4,280
- Portland, OR
On the Gen 2 anyway the holes have to be drilled in the cab for the AC fittings. The heater coolant fittings are the same as the non-AC box.
Cool thank you for the tips.On the Gen 2 anyway the holes have to be drilled in the cab for the AC fittings. The heater coolant fittings are the same as the non-AC box.
Thanks!Is this a factory system such that part numbers will be in the TM?
What is your truck serial number? If it's a TM part I will need the serial number to look it up.
Thanks General! I appreciate it!5930-01-573-8366
RD-5-11064-0
I see several on eBay for quite reasonable.
