- 16,066
- 22,648
- 113
- Burgkunstadt, Germany
This was the most interesting place I ever worked. And the picture shows only the halls where the pre-stressed, prefabbed concrete "things", forms are put together. The concrete mixing plant, curing section, and mixing tower are huge. "Situational awareness" from the second you walked in, till you got out to your car. Everything could bite you. The #5 Hall boss, only had his left hand. The right one got between an 20 ton bridge casting and an unmovable thing, that was moved after being struck.
