New owner of MEP 802A
Light in the Dark
5,161
MA
So the switch is doing what its supposed to... You are going to want to take the roof off the operator cube and look at the contactor assy for loose collections, corrosion, etc. Its a known problem spot, but typically can be disassembled, deoxidezed, and made to work again (unless waters gotten in).
Guyfang
22,239
Burgkunstadt, Germany
If you see the green light, then your control part of the output system is working up to the K1 output relay. So, after you take the top off, you need to check the rest of the output system. Start the set. Turn on your S5, (AC circuit interrupter switch). If the green light DS7 light, (Green light for the AC output) comes on, then measure from ground or N, to the AC input wires on K1, the then see if the output side gives you the same readings.
Guyfang
22,239
To see if plugging them back in does anything. Pretty standard thing to do when troubleshooting something.
Wouldn't it be easier to just take them out and test them on the bench? Apply voltage, watch it work, or not work. Then use a Multi-meter to check if the contacts are properly opening and closing? Pretty standard thing to do when troubleshooting.
heimlich
21
Houston, Texas
That's how you would test them before you throw them out.
