0.65:1 transfer case?
290smallcam
36
peru,indiana
Looking for a transfer case to replace the stock M813 one. Cant find any HD ones out there on google that have a high gear of in the range of .70:1 to.65:1 ratio? the Oshkosh 5500 has .90:1 ish ratio and is way to big! The M900's are .73:1, looking for a litter lower. Any suggestions.
simp5782
Feo, Fuerte y Formal
9,285
Mason, TN
Oshkosh units
55000 is .98
18000 is 1:1
30000 is 1.36
There isn't anything more overdrive than the T1138 I have ever found that is .73
there are not Any auxiliary cases numerically lower than .70.
You would have to go into a transmission to get more speed with a more overdrive ratio.
RTOOs are .83 .73 .62 OD. Spicer proshifts are .83 and .70
ALLISON 3000 and 4000 series are respectively the same. 4000 series are not available in SAE 2s however.
290smallcam
36
peru,indiana
did the math, running XZL 12:00R20 and HT740 RPM's are a little high. and that's with the m900 series T case. Thought there would be something out there>
simp5782
9,285
Mason, TN
So you are using a small cam or big cam with a SAE 1 housing to an HT740 in an 809 series that you have to raise the cab and front cap almost 7 inches to use? HT740s cost much more than a HT754 and have one less gear, almost mostly only come with Detroit ring drives.
Most vocational trucks use a manual transmission with an OD over an OD transfer case and they used single speed units for simplicity and they wouldnt want to go over 60.
You would be smarter and cheaper over buying an HT740/754 and a transfer case to buy a old dump truck with RWD Allison 3000 world series transmission that has everything you need for the swap. With preferred an 8.3 in it. You would just slide the Tcase back for the 3000 and have a Double OD. Over raising the cab and cap and having to move the case anyway
Or swap the 3rd members for some crash truck 5ton ratios. They are In the 5.63 range
290smallcam
36
peru,indiana
Wow 7 inches!!! That's alot. These are Future plans nothing in stone yet. The HT doesn't seem much bigger than the MT Series? Couldn't I just cut the floor out and weld up a tunnel, instead of lifting it 7 inches? Or would I fe better off buying a M931A1. Would the HT fit it better than my M813?
simp5782
9,285
Mason, TN
The mounts for an SAE1 are above the frame unlike SAE2 that are mid frame.
HT740 is 5 inches taller than the MT654.
This is what it takes to so SAE1 mounts in a m939 series.
