1009 leaf spring choices
rsh4364
15
greensprings ,ohio
Front: 3 leaf 1400 lb.spring or 4 leaf 1900 lb.spring ? Rear 5 leaf 1900 lb.spring or 6 leaf 2350 lb.spring ? The 3 leaf front and 5 leaf rear are stock on the 1009. Wondering how bad ride would be with the heavier rate springs.
rodent
Denver, CO
It will ride rougher. The best riding spring is going to be your leaf springs with many thin leafs. Its a night and day difference between a set of custom ORD springs and off the shelf or stock springs. The only issue with the custom springs is cost but If you really want a good riding spring then stick with the thinner leafs. If you're hauling heavy weight, then thats a different story.
http://offroaddesign.com/catalog/ORD Custom Springs.JPG
cucvrus
9,701
Jonestown Pennsylvania
DSCF3238 (1).jpgDSCF3237 (1).jpgHey Rick how about a 4" lift kit 4 leaf spring system complete in Pennsylvania? For the price of 2 new rear stock leaf springs? Trade. Then you can run with the big dogs and get big tires. That entire M1009 BODY is sprayed in Line X check out the design.
LastFbody
10
Milwaukee WI
Did the stock height 3 leaf packs on my front. Raised the front up a good 3 inches over my worn out originals, ride quality didn't seem to change for better or worse.
Think mine were made by a company called Triangle.
Tinstar
1,712
Edmond, Oklahoma
Triangle Springs are excellent quality.
They are also a ISO certified company.
Where did you get your springs?
LT67
499
Bowdon, GA
My M1008 and 79 K20 flatbed truck both have brand new 4 leaf factory type springs. They're a little stiff at first, but once the break in they're comfortable. Tire size also plays a role in ride comfort.....
LastFbody
10
Milwaukee WI
Got mine from a local old school suspension shop. They do mostly busses and semis, but they'll do the odd pickup or Blazer in my case. It wasn't a job I trusted myself to do correctly.
Those 4 leaf packs are probably not a bad idea really, the 6.2 diesel is heavier than a 454 even. I feel like GM may have gone not quite heavy duty enough on the original springs all for comfort's sake.
cucvrus
9,701
My experience in shipping and crating engines for shipment be it a small block , big block, or Light duty diesel. They are all with in 50 -100 lbs of each other. 100 pounds added to a set springs don't make that much/huge difference. That's like driving alone or with a passenger and a young light one at that. The 4 ply on front have 1/4" deflection with a large Fisher plow as outlined in my Mr Rusty build. They make no difference in ride quality but do set the truck nice and level. With out the plow they seem to stiffen it up nice. But as is new springs 3 or 4 play are new springs. they make the difference. Re-arching is a bandaid repair. I had a local guy sell me on that 2 years later back down at same height. Metal fatigue can not be reversed. Like fixing rust. It comes back with a vengeance. Have a Great Day.
rsh4364
15
greensprings ,ohio
Thanks Rick, I think I will stick with new factory springs with factory rates front and rear and add ord 1" zero rates front and rear along with their poly bushings that are grease able. Not looking for much lift, just a nice ride.
