10K vers 12k half shafts (size)
86humv
488
Texas
There are 12k shafts for solid, and vented brake rotors.[ different rotor end.....vented has larger circle between bolt holes ].
Retiredwarhorses
3,942
Brentwood, Calif
You need new upper spur gears in your Geared hubs for starters...
unless your your doing serious off reading, there is no need to change up to 12k HS. Just make sure you install newest style 10.3k
then while off roadong, learn to BTM correctly so you don't snap a shaft.
