14.00X20 on a deuce ..
williamh
589
SanDiego Ca.
thought i had seen that someone had done it but i tried to search for it and couldn't find it .. any one done it without moving the rear axles ??
Bidslinger
mo.
RE: 14.00X20 on a duce ..
Check out breelanr 's truck I believe he has 1400 x 20 tires. You might also do a search using his user name.
It is a nice truck.
1,814
Can't do 1400x20s without spacing the rear axles apart some. 395s or 14r5s are as big is you can go with the current axle spacing. Hot Rod Deuce has 1400x20 on his crew cab deuce!
