1942 White M2A1 engine and gearbox colors.
1,124
moar
Evidence of a different color on this oil canister drain plug
Oooooold school filter
Getting closer. Ceramic coated manifolds.
I rebuilt both the starter and fuel pump
D!rk
Belguim - Grobbendonk
Hey,
i have one probleme with the feulpump on the white engine. On the benche test, the pump is working ok. On the engine, not working. Prossible worn plunjer in engine.
How kan i remove the plunjer out of te engine,
SETOYOTA
419
georgia
I think a lobe on the camshaft operates the pump. If it’s worn you have to replace the shaft or possibly build it back up with more material by welding and grinding
D!rk
In the White AX engine, camshaft is not on the site of fuelpump, action is from the lobe on the camshaft by movement of one plunjer going to the opposite site for action on fuelpump. it is not logical that lobe on camshaft will worn, plunjer is the weak part ? Any info of foto for removement of plunjer is welkome.
