1952 M135 Fuel Pump diagnosis and rebuild
WMontana
Montana
Hey guys,
New to the platform and looking for a little guidance. I acquired two M135s on a property I bought. One is a 1952 W/O winch and another is a 1953 W/ Winch. I got the 52 going briefly but it wasn't receiving fuel, so I dove into the tank to find the pump and tank completely guncked up. I couldn't find a rebuild kit or replacement pump so I am in the process of cleaning up the existing one. I pulled the pump housing and found that there was no "external filter screen" on the housing itself and someone had replaced it with a solid piece of metal (as shown), therefore creating a box that didn't allow fuel through by any means that I could find. I pulled the "covers" on both sides and that internal screen that was basically impenetrable for fuel and cleaned it up. Can anyone given me some guidance on whether they've ever seen this or where I can find pump housing external "filter screen." Also anything I should do to help that internal impeller? It looks as if there is something welded or bolted to the inside of the pump housing that would prevent me from pulling the pump completely and rebuilding it. Needless to say its a weird setup that I stumbled upon. Any thought or ideas of how to get this thing working again would be super helpful.
Thanks,
Wyatt
02smokemaker
31
moodus ct
Are you sure those "screens" are just clogged badly?
Did you try and really clean em off?
Sent from my ASUS_I003D using Tapatalk
WMontana
Montana
I truly don't know, I'm trying to soak them currently. My only thought being that maybe they're some sort or porous metal? I will scrub them more and see what happens if I soak them for a few days in solvent then 1:1 seafoam and gas.
02smokemaker
31
moodus ct
I would do that then compressed air to blow it out!
Let us know how you make out!
USMC 00-08
135
Skiatook, OK
Thanks,
Wyatt
You might call Memphis Equipment and see if they have new fuel filter screens if you can't get those cleaned up. They have more parts than they list on their website. Tell them the part number off this photo. Their phone number is on the bottom of the page.
Here is a breakdown of the fuel pump. The first photo is of what you have,. The other three are very similar to what you have and should show you how it comes apart. I have gotten these to work before by cleaning up the brushes.
IMG_20231211_084721114.jpgIMG_20231211_083323162.jpgIMG_20231211_083338723.jpgIMG_20231211_083356466~2.jpg
This thread might also be helpful to you.
