1971 M818 5 Ton Starting issues
818 Test Pilot
19
Chicopee Falls Massachusetts
well haven't had to open my 1971 M818 Hood for years. Always started Always Ran fine. ok... question: My M818 Cummins have Glow Plugs? read that Cummins don't have glow plugs but a Heater Grid ? are these on newer Cumins or used on all Cummins. I know there's the one glow plug mounted on the intake side that is controlled by the switch on dashboard for starts. removed original years back. was inop. bought new one and haven't installed yet. thing is ol betsy started for years without plug. 2 Batteries are going on close to eight years old. engine doesn't turn over as quick maybe because of batts. Note: OIF1 logged in a bit more than 20,000 miles in 818s. the weakest part of the M818 I had was transfer cases went south. cargo strapped transfer case lever thru back window to spare tire frame to arrive at fob. never let enemy have my vehicles. usually by the time a unit goes to retrieve with a tow truck or hemmit next day everything mechanical is gone. always got issued a operational M818 for next mission. 931's were underpowered super singled junk.
Ajax MD
1,412
Mayo, MD
There are no "glow plugs" on the NHC250. As you said, there is just the one hot plug for very cold weather starts.
The procedure on the dash data plates explains how to use it in conjunction with the hand operated fuel pump on the dash. The burning diesel pre-warms the intake chamber for easier starting. There's not even a heater grid that I'm aware of.
Yes, if the batteries are getting tired and spinning the engine more slowly, getting up to combustion pressure will make starting more difficult. I guess I'd start there and see if starting improves.
818 Test Pilot
19
Tanks for the Glow Plug answer. Yup never ever used that Prime T handle on dash in 25 years of driving Army Trucks or the Glow Plug Heat Switch. Maybe I’m overdue now that the Truck I’m driving now relies on Me to maintain. Have no idea where I stashed the Plug I bought years ago from O’ Reillys. Ohh and one more detail I tried t handle primer and didn’t prime. The petcock under hood was closed. Usually don’t publically announce things like this. Have built Turbine engines GM Engines ect. Hoo Ah.
Floridianson
2,480
Interlachen Fl.
Myself whenever any 809 series I had and was known to run but I then had problems with starting I would first run in the thumb screw.
If that was not the problem then I moved on.
PS, I always check the emergency stop was pulled and not reset.
porkysplace
1,486
mid- michigan
When was the last the fuel filters were changed ?
