Liv2Dive2
- 0
- 6
- El Paso TX
So I'm a new guy here, and I'm in the process of getting my CUCV squared away and I noticed I had a bit of a leak under it, after replacing the heater core hoses I knew were leaking I saw this and wanted to bounce my thinking off you guys who have been there done that.
So this is on an 85, I believe it's a NP208 transfer case, and it looks to me like the rear seal is leaking. To repair this I need to pull the drive shaft, replace the seal, do I need to actually pull the extention housing to do this, or can I just clean it in place and replace the seal...is there anything else I should look at or replace while I'm at it.
Here's a pic of the leak. The seal should be a timken part 9449 correct?
