coachgeo
- 3,373
- 113
- North of Cincy OH
guess it would matter the engine? If it is total mechanical then likely the wtech II?II or III...
Question already answered in post #7. Also the flasher module.
Mine isn't. It's an sp3070. If the wiki is wrong someone edit it where it states the MD3070 came about with the A1's.They are all md3070 trans. ....
Thanks for this. I gotta reprint my wiring diagram bigger so I can read it and find those.Its located at H57 on the schematic. TL29 is ground(has wires numbered 3015 and 3017 attached), TL28 is the power input(has wires 1441 and 54 attached to it). which normally receives 24V from relay K19 and ultimately CB79... You should be able to confirm ground with an ohmmeter once you break the circuit/lift the leads on one side of the solenoid...
So did the solenoid go clunk when you jumped it? Did you get fuel all the way thru the system like I described back in post #33? If so, it should have started if the lift pump in the governor is pumping fuel while cranking. You can see this with that plug on top of the secondary filter loosened while cranking...Got a chance yesterday to get the motor fired up. Tried jumping the fuel solenoid but it didn't start. Shot some ether into the filter housing and it fired right up. So, we know the engine at least starts. Now I need to figure out how to get the main harness out from behind the heater assy. so I can see if I can conceivably re-solder the cut wires.
If you're really intent on trying to fix the harness, pull the heater. Its easy and will make a lot more room to work.Got a chance yesterday to get the motor fired up. Tried jumping the fuel solenoid but it didn't start. Shot some ether into the filter housing and it fired right up. So, we know the engine at least starts. Now I need to figure out how to get the main harness out from behind the heater assy. so I can see if I can conceivably re-solder the cut wires.
The solenoid didnt make any noise. But the primer pump did move fuel.So did the solenoid go clunk when you jumped it? Did you get fuel all the way thru the system like I described back in post #33? If so, it should have started if the lift pump in the governor is pumping fuel while cranking. You can see this with that plug on top of the secondary filter loosened while cranking...
