2009 vin info thread
KCclay
Fontana, Kansas
Carnac
I have an 818wo/w that has a hand etched data plate. the serial number on the Data Plate is slightly different than the serial number on the frame.
Frame serial number is C12610037
Data Plate serial number is C12410037
Data Plate say the truck is an AM General 05666970
Purchased in Missouri
MONG 1138 MYC
There is a small 54 stamped verticaly on the frame after the serial number.
Any info you can find on this truck would be appreciated. Is it an AM General? What year is it?
Thanks for the help.
Happyland1410
Ada, Oklahoma
Carnac,
This is for a 1967 Kaiser M45A2
a. Serial Number (VIN number): 04050970053410052
b. Registration Number: ?
c. NSN without dashes: ?
d. Where you bought it: Through GSA @ Oklahoma Forestry Services
e. Bumper numbers: None visible
Here is the data GSA provided in case there are any other helpful clues in it:
YEAR: 1967, MAKE: KAISER , MODEL: M45A2
VIN: 040-50970-0534-10052 MILEAGE: 20758
1967 KAISER CAB & CHASSIS, 2 1/2 TON, 6X6,
MDL:M45A2, 06 CYL, DIESEL, STD,
VIN:40-50970-0534-10052, EST MI:20758,
1243N79288OK18
Thanks!
CARNAC
The Envelope Please.
620
Corpus Christi, TX
Carnac,
Very little info.
M35A3 wo/w
SN 505276
NKOM5K
Picked from GL at Barstow.
Thanks for whatever info you can provide.
Cheers,
Clarke
Organization:180TH FA BN 02 HHS 155T Location:PHOENIX
ARIZONA
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M44A3 NSN:
2320013832047 Serial Number:
505276 Registration Number:
NK0M5K Usage Miles: 11113
Info Sep 04
CARNAC
620
Corpus Christi, TX
Carnac
MONG 1138 MYC
For legal purposes, you have to go with the number on the frame. I would double then triple check and verify it and then work on getting the sf97 with the correct info. Keep in mind the govt doesn't have the issues with correcting info that you will have nor will they have to pay like you will. All it took was for some pvt to type it in wrong and then instead of correcting it the way they should have, they have a different dataplate made. Not a common thing but can see it happening.
Organization:1138TH TC CO MDM TRK CARGO Location:JEFFERSON
MISSOURI
Nomenclature:
TRUCK TRACTOR 5-TON Model:
M818 NSN:
2320000508984 Serial Number:
C12410037 Registration Number:
5A13370 Year of Mfg:
1970 Usage Miles: 12138
Sep 09
CARNAC
620
Corpus Christi, TX
Carnac,
1243N79288OK18
Thanks!
This one appears to have some issues. Will need to verify it is an M45A2.
First separating the reg# from the serial (VIN) number I have a reg# of 04050970. A search on this is a blank however there is a 04H59#70 series from 0 to 9 where the # sign is.
Looking at the SN 05341005# is the start of a series for a set of M109A3 shop vans. The # ranges from 0 to 9 but you specific number '2' is missing from the series.
It leads me to wonder if your truck may have started life as a 109 shop van and got bastardized before or after leaving service.
Verifying the frame number would be a start.
ClarkeF
Hestand, KY
Funny! I'll be bringing her home then _ back to Phoenix area!
Donation made!
Thank you!
ARIZONA
Nomenclature:
M44A3 NSN:
Info Sep 04
donkdonk
Norman, OK
a. Serial Number (VIN number) - 032520379
b. Registration Number - 04H05369
c. NSN without dashes - ?
d. Where you bought it - Ft Sill
e. Bumper numbers - 4341F79 A400
Thanks!
CARNAC
620
Corpus Christi, TX
Carnac Please and Thank You
1986 M1009
1G8ED18J4GF110547
REGISTRATION # ?
2320011232665
Anneville, Pa
Bumper # ?
Organization:HQ, 55TH BRIGADE COMBAT TEAM, 28TH INFANTRY DIVISION Location:SCRANTON
PENNSYLVANIA
Nomenclature:
TRUCK UTILITY 3/4TON Model:
M1009 NSN:
2320011232665 Serial Number:
J4GF110547 Registration Number:
NF0FCJ Year of Mfg:
1986 Manufacturer:
93219 Contract Number:
DAAE07-82-C-4060
Usage Miles: 20558
Info Sep 08
CARNAC
620
Corpus Christi, TX
Thanks!
Organization:
HQ, 434TH FA BDE
OKLAHOMA
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
32520379 Registration Number:
4H05369 Year of Mfg:
1969 Manufacturer:
65909 Usage Miles: 58809
Jan 2000
sandcobra164
287
Leesburg, GA
CARNAC,
I purchased a truck recently from Ft. Rucker, AL
ID # 052517881
Reg# 04B07171
NSN 2320000771617
Unit Markings 1 145th on Passenger Bumper, D22 on Drivers side of bumper.
When you get a chance, please run the numbers so that perhaps I can learn the history of my truck. It was represented as an AM General on GL, it is stenciled CARC 08/96 and the motor tag has a build date of 02/90. Can you see if this was a rebuild during the 90's as well? It's in great shape and I'm very proud to have it.
Thanks,
Joseph
CARNAC
620
Corpus Christi, TX
CARNAC,
ID # 052517881
Reg# 04B07171
NSN 2320000771617
Thanks,
Joseph
Organization:AVIATION COE Location:FT RUCKER
ALABAMA
Nomenclature:
M35A2 NSN:
52517881 Registration Number:
4B07171 Year of Mfg:
1971 Manufacturer:
65909 Usage Miles: 294539
Info April 1996 when it was being transferred to HQ 1st Bn 145th Infantry and then to D Company of the same unit.
