- 14,593
- 4,637
- 113
- Buchanan, GA
I'm going to swap in a 4l80 into my cucv. It will have a proper TCM, but first I want to see if there's a uber cheap way to swap in a 4l80e for a "manual" control without relying on the shifter. The rotary switch is just a double pole 5 position switch to allow me to juggle through the combos for the A B solenoids. The button is a latching LED switch to lockup TCC. I'm going to swap the brake light switch with a normally closed/normally opened to allow the TCC to unlock when the brake is pressed. The whole setup with a switch/button/wire should be under $50.
Sent from my SM-G965U using Tapatalk
