Dasgog
- 148
- 43
- Tucson, AZ
And I get that,I do, I do.. But I am now where I am at and cool, ill throw in endless oil, but now I have a tank thatYou're getting crappy fuel, it more than likely is that vegetable oil mix Fuel and that vegetable oil attracts and retains water like a mofo .
This is what happens when you go to the fuel station and run that "perfectly clean" diesel in your old Deuce so that you won't have any problems, it's just the opposite .
If you haven't figured it out by meow, fuel nowadays is total crap, gasoline is even worse, it's made from corn which attracts water like nobody's business .
The fuel tank in my old Deuce is full right to the the top with diesel, used motor oil, and ATF, and I've never had a rusty cap, far as I know it's been on there since 1963 but I can't prove it .
Well naturally I did an oil change a month ago and then brought the oil to a local shop to dispose, I have none, so ignorant question, can I throw in the remaining new/unused motor oil for now to at least start this conversion to diesel/oil mixture?You're getting crappy fuel, it more than likely is that vegetable oil mix Fuel and that vegetable oil attracts and retains water like a mofo .
