404 pivot mounts on frame and radio box ??
joeblack5
238
State College PA
Hi folks, I am looking for some help.
Looking for pics how and where Mercedes located the the pivot point of the radio box.
It looks like that the cross member rests on top of a normal bed support? Are these the battery cable I see on the right in the picture?
This box looks like it is missing the floor panels? The floor support seems to be bowed, at least not straight... Is the floor in the box curved?
Is this the front mount directly behind the cab?
Is there another one like this on the end of the frame?
Anybody a link to better pictures or willing to make pictures ?
Anybody has these parts laying around?
Many Thanks.
Johan
Any pictures of the hardpoint connection of the box to the frame?
joeblack5
238
State College PA
With some post to post searches at benzworld i found some pictures post from "truktor" searched for him over here.
Either way, thank you.. funny enough the pivot in the previous post does not look exactly the same,, other truck or model?
unimog 404 box frame mounts truktor 176b_1.JPGUnimog 404 box mount drawing fuko_lagerung.jpgunimog 404 box frame  truktor 47_1.JPG
Ferretboy
471
Ripley,ohio
Hey johan....your bed frame looks alot like mine....have to dig out some photos....the tube running down the center....you know what thats for? Stowage for the tow bar!!!! I will try and get a photo of mine.
Ferretboy
471
Ripley,ohio
Oh sorry somone elses bed frame....i think the problem you will run into putting a school bus body on is the twisting of the frame....the cab has a three point connection...the bed frame also....they have to flex separately.....the hard connection beween the two i dont think will work....im not an engineer....but knowing how the unimog frame twists and the cab and bed three point mount is....i cant see a hard connection between them together.....
Ferretboy
471
Ripley,ohio
Well sorry again...after running to the garage to inspect the old 404....i see it has a 4 point connection a pivot point at the front a pivot point at the rear and hard connections each side midway.
