5ton wrecker fun
Greasy
64
Bakersfield, Ca
Last weekend I decided to take all the missing wrecker equipment that I have been collecting over the last 3 years and set up my M543 to tow a M35. Saturday 11/13 a museum I volunteer at was having a “wings and wheels” car, airplane, motorcycle and boat show. What better place to tow around a broken Duce at!!! Below are pictures my wrecker hooked up after being pressure washed. The last photo is my wrecker, the Duce, M37 and a M101. If this picture was black and white, it could have been taken in the early 70’s. C37E690D-E983-4C2C-A9C0-56BD1463C460.jpegC0B53828-B7FA-4F7C-91A7-C921E1FC24B9.jpegEDB09957-A4F1-4AB5-AE27-F37DCBD16E8A.jpeg29278AB5-4FD6-4B96-A310-B036226F467D.jpeg
zebedee
conceptualizer at large
678
Central NY
Why did you use cable on your hook as opposed to hooking directly to the whiffletree?
... beat me to the question!! and whiffletree is on backwards - must have had Soldier B assist hooking it up rather than use the crane hook and the whiffletrees loose 'staple' to position it.
Greasy
64
Bakersfield, Ca
Looks great!!
Thank you for the compliment. When I hooked it up, the block hook was really close to the duce’s grill guard. Secondly this was the first time I’ve ever hooked the wrecker to another vehicle, learning curve figuring it all out 😁 (and loved every minute of it).
Greasy
64
Bakersfield, Ca
Ha! No soldier B involved, did it all by myself (Armstrong). Took my time setting up the axle clamps followed by the tow bar, using a broken pallet on edge to hold the tow bar at the right height to catch the pintle hitch. Keep the information coming, I appreciate the guidance. My next hook up, I will try hooking the block hook directly in the waffle tree, it gets close to the Duce grill guard.
Floridianson
2,477
Interlachen Fl.
Think the hook would have been OK and just turning it around so hook is facing tow truck. I have done some lift tows and never did it but thought about a shackle on the boom hole and a chain running down to the truck. Just in case the cable broke. Do not know if really needed and I do not know about you but when I was towing lift or otherwise was always thinking / praying nothing would go wrong. I got lucky on all my tows and no problems.
