77' Jeep M35A2 leaking hubs in the front.
kellereaton
York, South Carolina
Let me start by saying, I just bought my first Deuce and I love the truck more than I thought I would so far! It a 1977 Jeep with the Continental multifuel engine. The truck runs strong and I plan to use it to haul firewood, move materials and that kind of thing. The only problem I need to address are the front hubs leaking like a sieve. I've got the repair manual on a thumb drive, can anyone pinpoint what the issue might be? There are some rubber boots that are pretty chewed up so I suspect that has something to do with it. Is this something I need to fix before I drive the truck any more? I've attached a picture. Thanks!
KRedd
Germany
Its leaking what? If its 80/90 wt then it could be the inner axle seal. If its just oily grease then the CV boot.
tie6044
42
Blaine, MN
The boots will keep the grease in but that looks more like a liquid=gear oil so yes you need to replace the oil seal in the housing. When the boots get cracked or torn you will usually see chunks of grease coming out.
frank8003
4,978
Ft. Lauderdale, Florida
See that plug in the middle of your photo/ That is the plug that is to be removed when greasing as in the TM
m715mike
3,822
Montgomery, Texas
I see three options:
1) Oily grease. NAPA bearing grease has done that to me.
2) Gear oil - seal is bad.
3) Break fluid. A bad wheel cylinder has done that to me a couple of times.
If you are going to take the time to dig into it, replace everything. The parts are cheap enough.
Here are some resources:
I like the axle boots from rockwelloffroad.com
Also, the last time I took an axel apart, I had the break drums turned at NAPA.
frank8003
4,978
You can drive for years with ripped boot.
