- 403
- 992
- 93
- Wapakoneta, Ohio
I have an 802a with 112 hours and it was missing batteries when i got it. Also in the video from GP it was a crank no start and the no fuel light was on. I got batteries in it today and filled with fuel. No start, fuel shut off works, the screen by the fuel pump was loose and bent. took that off and the threaded piece off the top of the pump was loose. tightened and removed the bottom hard line. pump makes noise no fuel coming out. I made a mess getting some fuel in the fuel line on the top and got it to fill the fuel line and the machine ran for 2 minutes. So confident the pump is bad but wanted to share a picture because i believe some additional hard ware filters have been added as i do not see them on the tm Parts list
