809 Series 5 Ton Steering Box Replacement
MosquitoRanch
South Mississippi
I have a M817 5 Ton that has an unacceptable amount of slack in the steering. I was wondering who could tell me what all steering boxes that may interchange with it. I was hoping maybe some of the M939 Series stuff may work. Or maybe I can find some nice NOS steering boxes somewhere.
162tcat
44
Washington
I have the same issue. Did you try the adjustments listed in the TM? I'm going to try that first before replacement
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Check to make sure its not the mounting bolts! I had lots of slop, turned out to be the bolts were loose. Its no fun to tighten them either.
73m819
315
gainesville, ga.
Also check the U-joints in the steering shaft, check for play in the drag links, while checking things, make SURE the axle U-bolts are tight and that the spring leaves are not moving on them selfs because of a broke center pin, ALL the above WILL cause loose steering.
