84 m1009 cucv chevy blazer build-up
2INSANE
819
Belgrade, Montana
Took a trip up North Meadow. The new Derale Oil Cooler blew out on me… took 10 quarts of oil to get her back home. Barely made it back. If it was not for the oil temp gauge, I would have lost another motor. Anyhow, it was a fun trip!
2INSANE
819
Belgrade, Montana
Nice trip! Where was the failure in the cooler? Was there a fitting failure or internal to it?
The hoses and fittings are dry. It is for sure internal. Not sure what happened but there is no way a rock could have hit it. It could have been from the body flexing when on the rocks or just a poor design of the cooler. I have a new one on the way.
It was interesting… because I put the oil temp gauge on the oil pan, when the oil level went below the gauge sensor, the oil temperature quickly dropped from 180-120. The oil pressure was still good but I knew I had to add oil once the temp gauge got cold. Glad I put an oil temp gauge on!
2INSANE
819
Belgrade, Montana
Got the new soft topper on today. Wonder how many years this one will last…
If anyone wants my old one, the windows could be fixed with vinyl sheet and some sewing. Comes with new hardware. Let me know. Free just pay shipping.
2INSANE
819
Belgrade, Montana
Today I wire wheeled a lot of rust on the body and touched up all the paint. Also got the truck tailgate painted as well. Got the paint from Rapcoparts.com It looks a lot better.
2INSANE
819
Belgrade, Montana
Today I got my toenail removed. The Dr said take it easy for a week. First thing I did when I got home was remove the downpipe and replace the bad cold advance idle switch.
Then removed the Dinosaur GM1 turbo with a kink in it and started the HX35W swap. Almost done. Just gotta redue a couple of the glow plug wires to get them further away from the heat, cut the turbo housing and hook up the intake. Got dark so I’ll finish it tomorrow.
19,255
Yeoooow! Dang that looks like it hurts... Been there. Done that and it isn't any fun.
As far as the truck and turbo is concerned, it looks good!
Guessing that was a nice way to keep your mind off your sore toe.
2INSANE
819
Belgrade, Montana
This was the second time they removed the same toenail. The first time was more painful for sure. It was not suppose to grow back, but it did… This second visit was free:) Too much stuff to do on the days off to let a toenail limit me.
I hope the turbo gives lower egts and more efficiency with boost. Keeping boost 15 psi and lower is the goal.
2INSANE
819
Belgrade, Montana
The correct oil feed adapter size for the
HX35W is:
M12x1.5 Metric Male x 1/4" NPTF Female
This one I ordered has a metal compression washer instead of a rubber O-Ring to help seal.
2INSANE
819
Belgrade, Montana
I did some experimenting today after work. I wanted to see if I could get faster turbo spools at lower RPM’s by changing the made in China Hx35w compressor wheel and housing with the made in USA compressor wheel and housing.
Measuring the compressor wheels…
Made in USA
Inducer=53.05mm
Exducer=76.47mm
7 Blade
Made in China
Inducer=52.03mm
Exducer=82.49mm
8 Blade
The made in USA wheel and housing swapped right in with a perfect fit!
WOW! What a huge huge difference! It spools much faster, especially at lower rpm’s, the jet engine noise is about twice as loud and egts are about 75 degrees lower making it 175 degrees lower in total compared to the old GM1.
The USA wheel does have a small nick in it. I will replace it with a new one that has the same specs to keep the balance correct. I also plan on turning up the fuel 1/8th of a turn now that the egts are lower.
The elevation I am at plays a big roll in the size of compressor wheel.
2INSANE
819
Belgrade, Montana
Another trip to the Tobacco Root Mountains for the books! 4 people, 4 dogs and gear. Passenger and cargo space, wheelbase is why the M1009 is IMO the best budget wheeler one could get.
4sdair
South Central Kansas
Interested in the outcome of your china hx35 turbo swap. I have a m1009 (6.2) with a gm4 turbo. The turbo is starting to leak around the seals and I'm thinking about a hx35w swap. Lower egt and quicker spool sounds good to me.
