Air Governor Installation- is this right?
dcwilkie
Huntsville, AL
I replaced my weird- acting air governor with one from OD Iron (a D2) and now my air pressure acts even stranger. Before it was steady, but constantly at 120 psi. Now it slowly builds to about 100 and then drops off rapidly if I engage the front axle or if I even have to brake alot. It tends to stay around 60 psi during my test drive and never fully recovers even during the 5 minute shutdown. Here's some pics if that helps.
I had to make an adapter fitting out of a 1/8 in pipe thread coupling to shorten the tee so the tubing would reach (tubing to air tanks and cab IIRC). Before I start screwing around with the air adjustment, I thought I'd ask the experts here.
G-Force
allendale nj
In your third picture with what ports you plugged did you plug the exhaust port?
I think that might need to be left open. But I'm not sure.
dcwilkie
Huntsville, AL
That 'splains it- I plugged it!
Will get a 1/8 pipe fitting with a screen on it and swap it this evening.
DDave
p.s. Gimp- I almost couldn't remember what this thread was about thanks to your avatar...
Heavysteven
10
Hickory Flat Ga
Thanks dcwilke for posting this thread. I installed mine today with good success.
I had to use a 1/8 ntp nipple close and a 1/8 ntp coupling to make this regulator work.
Thread in to decrease pressure and thread out to increase. The TM had me doing it backwards.
This is an easy fix so if your air compressor runs non stop at 120 psi fix it.
