- 4,294
- 3,952
- 113
- Brentwood, Calif
This is what out of control Algae looks like, this is essentially tar, it’s in the tank, fuel lines, tank sock, pickup tubes, lift pump, filter, filter housing, fuel line, injection pump…solution was, everything listed was replaced.
The pump in this truck was essentially a brand new 6277, unfortunately it needed a new pump to run…a simple pulling of the fuel level transmitter is the easiest way to verify tank conditions.
The only way to clean anything is with brake cleaner…once done, and everything back to running condition, treat the fuel with a biocid.
