any good led work light options ?
sweetk30
horseheads,ny 14845
long time since i posted up . . how you guys doing these days ?
i am fabbing up a set of bumpers for a friends blazer and he wanted painted bumpers over chrome so i scored a set of military take off's and he wants some led lights in place of the black out lights . any one do this mod and find a good unit to install with min mods ?
thanks and have a great day guys .
ke6axc
Santa Rosa, CA
I found a set for the rear bumper that fit perfectly on eBay. I looked and couldn't find the seller just now. I have them wired as reverse lights. Work great.
Sent from my LG-LS777 using Tapatalk
Kaiser67M715
26
NH
I used Blazer brand, flush mount LEDs with great success. Does require a larger hole, I have them wired to an on-off-on switch, one of the "on" position is wired to the reverse lights, the other "on" to ignition so the lights can be used as an auxilary. Because of the way the switch works, I can use just one relay, to supply power to the rear lights, with no fear of backfeed.
The set I have installed in my K2500 is listed as omni-volt, 6-32volts.
Sent from my SM-S920L using Tapatalk
