Anyone building a Gun Truck based on current conflicts
jeffhuey1n
SMSgt, USAF (Ret.)
1,283
Laramie County, Wyoming
There a couple people that have indicated they were trying to gather up the parts to create a more modern gun truck. Iron Horse is one example that I’ve seen pictures of and used as a model for creating said truck. You might try reading James Lyle’s Hard Ride series.
DanJ
Howell, MI
The reason I was asking is I have what I believe is a full Hunter box setup with ballistic armor, gun mounts and ballistic glass. Was hoping maybe someone had one built I could see the inside of or just some better pictures. From digging1280px-Gun_Truck.jpg around online it looks like they built around a 100 of these kits.
DanJ
Howell, MI
I would like to see the inside because the kit I have has 6 gun mounts but I have not seen any pictures with that many. I wounder if they all had that many so they could reposition the guns as needed.
jeffhuey1n
SMSgt, USAF (Ret.)
1,283
I got these from Lawrence Livermore Labs website. The most I’ve seen on older trucks was only limited by the crew’s ingenuity and available resources. It appears there are four guns per truck in the two truck photo.
beerthirty
iowa
Rolled around in one in 07-08 to deliver supplies to a nearby IP/IA area. Typically we would mount 4 crew serve weapons. 1 on each side midway in, 1 on rear, and 1 on the front only if it was lead vehicle. No idea on the kits, ours was built by a air force maintenance crew and was not a kit built product. I'll see if I have photos of it.
DanJ
Howell, MI
The kit I have has 8 mounts, if it was setup using all that is some fire power. It is the same kit in the above pictures but 3 color.
