B pillar rattle
Predator42
Pleasant Grove Utah
is there anything inside the B pillar that can come loose and rattle around? when I drive it sounds like a loose bolt is hitting around inside at the top of the pillar. only happens at certain speeds too.
Action
1,552
East Tennessee
nope, you can take it off in a few minutes and shake out anything that may be in there. Or make a fast turn and it should slide to one side. It may just be echoing up the metal, though. The b-pillar is hollow and both ends are open.
Bulldogger
609
Quantico VA
On my HMMWV it was the d rings for the rear curtain smacking against the underside when the bouncing was just right. A couple of small adhesive backed foam chair foot pads gave them something soft to hit.
Bulldogger
