Ball hitch surge brakes
rustystud
2,492
Woodinville, Washington
I will never use surge brakes again ! I was in a rollover accident because the surge brakes would not apply properly. They need a hard push back to apply and when your on ice or snow you cannot always do that.
porkysplace
1,486
mid- michigan
And if not used regularly on electric brakes the backing plates rust and cause the magnets to hang up keeping the brakes from releasing .
rustystud
2,492
That why my backing plates are galvanized steel, and I always check the brakes before going out with the trailer. You can test your surge brakes, and they still will function poorly unless it is a perfect sunny day.
