- 5
- 6
- 3
- Houston, TX
***LAST OF IT’S KIND***
BARELY USED 2012 Titan TXD 4400 Off-Road Truck
VIN 51JJ0ECL0CA900161
316 Miles
* Upgraded Cab with 3-Man, Ergonomically Adjustable Air Driver Seat and Steering Wheel
* Cummins ISB-L 6.7 Liter Diesel Engine with 325 HP
* Seven-Speed Fully Automatic Allison 3700SP Transmission
* Full-time all-wheel drive
* Locking Rear Differential
* Anti-lock Braking System (ABS)
* Power Assist Power Steering
* 153.5” Wheel Base
* 22” Ground Clearance- Loaded
* 14.4”Ground Clearance- Under Axle
* 17,214 Lbs. Vehicle Curb Weight with Fuel
* 5,000 Lbs Payload
* Air Seat
The 6.7-liter Cummins turbodiesel inline-six delivers power to all four wheels through an Allison 3700SP seven-speed automatic transmission and a locking rear differential. The cab features power-adjustable air-ride captain’s chairs upholstered in black cloth. The BAE Systems steering wheel frames a 120-km/h speedometer, push-button transmission controls, a digital display screen, and gauges for fuel level, diesel exhaust-fluid level, coolant temperature, voltage, and front and rear brake-fluid pressure.
Used by the U.S. military for many years, these vehicles are considered the most sophisticated off-road, multi-purpose tactical vehicle in use, and are capable of operating anywhere in the world on primary and secondary roads, as well as on trails and cross-country in weather extremes from -50°F (-46°C) to +120°F (49°C). The XD 4400 is based on the BAE Systems Family of Medium Tactical Vehicles (FMTV) architecture, and this two-axle standard cab example is one of 50 produced for the civilian market under the Titan brand.
It’s the perfect base to mount your own camper cabin. We will paint it to any color of your choice. See sample colors on the attached photos.
$95,000, Denver, Colorado
Contact Matthew Efron at 281-413-6479 or matthewefron@outlook.com
316 Miles
* 153.5” Wheel Base
* 5,000 Lbs Payload
* Air Seat
