trvctor
- 39
- 13
- Pennsylvania
Hi all. Wanted to ask what you would recommend as the best way to achieve the rough texture that CARC has without actually spraying the real stuff.
I was about to buy the current-spec type 9 single stage waterborne CARC from Sherwin but cancelled after the primer+catalyst and topcoat would have come to around $300.
I read that many people recommend Behr as a solid option for an accurate 383 CARC alternative but the color seemed the slightest bit too dark(almost beginning to lean toward forest green, but still passable) in my opinion. I found Sherwin will actually be able to do the same thing using the FS code 34094 and their sample was just a smidge lighter and looks more accurate in my opinion.
In my mind it seems that getting a flat and matte Raptor Liner made up in 383 green may be a solid option considering the affordability and slight texture of the coating PLUS it's also polyurethane which I feel makes it a good contender for a CARC alternative, as CARC is polyurethane-based and the raptor liner could provide similar properties to CARC in terms of resistance to solvents spilling on the finish. They currently don't provide this color but I'm hoping after I get it ordered it might save in their system and make it easy for them to make subsequent batches.
Has anyone else been able to achieve that roughness of the CARC paint with regular paint? Would love to hear yalls experience. Thanks!
