Bought a M37
snowtrac nome
137
western alaska
nice rig I have one I should finish up some day as others said . they look military and are just the right size I cringe every time I watch A-team re runs and see how many m37' were totaled by that show.
rickf
1,322
Pemberton, N.J.
IT RUNS! Took a lot of coaxing but it finally got going. Best I can tell from the paperwork I got the last time it was running was at least close to 20 years ago. So now I can rebuild the carb and start replacing all the gaskets. And get that whatever it is out of the gas tank!
tobyS
816
IN
I had one back in the 70's that I must have hauled a couple hundred tons of large rock for a solar system, hand loaded and un-loaded. It's probably one reason for my bad back today. I remember being able to walk faster than it in low gear. I have to admit...a Cummins 4b would make a sweet re-power.
You have a really nice one!
rickf
1,322
Pemberton, N.J.
Put some Marvel Mystery Oil in the gas! The valves have a tendency to stick after sitting a long time.
Once I get the gas tank out and cleaned out and sealed I will do just that. right now it is running on a gas can. It actually still has gas in it from ????. Kind of hard to describe that smell! I disconnected the line to the carb before I even tried to crank it with the plugs out and Seafoam/Marvel mix in the cylinders. The fuel pump was pulling the nasty garbage up from the tank so I disconnected the line from the tank. The valves are all working well, it idles at around 400 just ticking right over. It does have quite a few exhaust leaks around the exhaust manifold.
CGarbee
511
Raleigh, NC
Good to hear that it has made it home and is in recovery.
I look forward to seeing it in action this fall when you come to the rally... ;)
