Cab airbag upgrade
coachgeo
3,369
North of Cincy OH
Well there is no frame mount structure above this to attach to for a pull type down limit, you would have to add a tower of some sort. Using straps for something like that is not the best in my opinion anyway as I don’t think they age well and have a cyclic limit. ....
Good point on wear limitations. There is a place to put it though.... its just not on your truck anymore. Well..... not in this area of your truck anymore :beer:
below is bad drawing. Attaches on the support member there.... runs down a ways then loops back up where it attaches to the cab suspension piece. As cab goes down it un loops more and more till reaches limit..... which should mostly never happen.
ramdough
1,728
Austin, Texas
I would keep a close eye on the bags and straps. The 83035 shock you chose has at least 1“ more travel than the bag is supposed to have. I have seen 2 different specs for those bags, 3”- 6” and 2.88”- 6.25” Or between 3 and 3-3/8” of travel. That shock has a bump stop and cutoff valve on the extend end which occupies the last 1/2” of travel, but it does not have anything on the compression end…
I started designing mine last year, then had to put it away for a bit to complete other projects. This discussion coaxed me into dragging it back out, as I am also to the point where I need to do it now:) After I did some measurements on my one mostly sealed bag to try and calculate the piston surface and volume, I was looking at those chassis tech #2200 bags As they appear to be a good size to replace the originals. I had my selection of shocks down to 3 or 4 Possibilities. The Gabriel catalog is cool in that they publish most all the important information right in their catalog…
The 4 things I understand about airbags is you don't want to exceed design pressure. You need to position them so they cannot rub on ANYTHING, and your mechanical structure must hold them in alignment and restrain movement within their limits. You probably want to protect them from UV as much as possible also...
If the bag can be squished beyond its compressed measurement, the convolutions will rub on each other internally or the internal part of the end crimps can cut into the bags, and eventually they will fail. The only thing to stop this on this shock without a compression bump stop, will be its hard mechanical/metal on metal limit.
When you over-extend a bag it pulls the ends of the bag over against the edges of the crimped caps. This contact/rubbing damages the material and eventually the bag will fail there. The hydraulic cutoff and bump stop in the shock, along with the strap, will limit upward travel. If the bag is on its lower limit with shock fully compressed though, it will exceed bag travel before it even contacts the shock bump stop. How serious this difference is remains to be seen but they picked those compressed/extended numbers for a reason… Straps also don't like being extended and shock loaded for the same reason airbags dont, and if they are limiting the travel will abraid where they pass thru their buckles.
I hope these observations are not taken the wrong way, as that was surely not my intent. I most definitely appreciate any and every journey taken into the unknown, and those brave enough to share the experience:) This setup may and probably will run for a very long time without problems because the shock resistance is able to absorb the typical energy and will keep the bag within travel limits under normal conditions. Where you might run into issues is prolonged rough road, where the shock warms up and begins to fade, or as the shock gets old/worn. This will allow greater and greater travel, and shock, bag and strap may start to hit/exceed their limits.
I would be curious exactly how much it moves in normal operation. This could be done fairly easily with a bracket with a hole in it attached to the frame and a rod attached to the cab that passes thru the hole in the bracket. Onto the rod you slide two small pieces of hose, one above the bracket and one below, that have just a little resistance to being slid on the rod . Once inflated to normal ride height, you slide the hose bits up against the bracket top and bottom and go for a drive over your railroad tracks, and then stop and measure the gap between the two pieces of hose that have marked the high and low travel points…
The distance from the normal ride height to the upper and lower limits could also give you an idea how well the spring rate, and the compression/rebound numbers for the shock are dealing with the loads that are being applied… for instance if it goes up farther than it goes down, you could use a shock with less compression dampening, or add some air volume(small tank) to the air spring plumbing, to lower the spring rate to get the movement more into the center of allowable travel.
Do you kind posting the parts options you came up with? Maybe we can all look at them?
Ronmar
6,745
Port angeles wa
Sure, Same chassis tech #2200 bags and I will start with a Gabriel 83057 shock. The original travel is I believe ~1.75” This shock has 3” total but has a bump stop on each end, #242 of compression and #364 of rebound resistance at typical velocities. So just over 2” of smooth travel between the bumps, with nearly 1/2” of heavilly supressed travel at top and bottom end…
I will measure total typical travel with this setup and see if I need to make any changes to air spring, spring rate or shock/dampening. I have 3 other shocks I can use that are the same mount bolt size, length and travel, but all with higher dampening values.
Ronmar
6,745
Port angeles wa
Each bag, probably around #400? cant find my absolute pressures in my notes, just the differential pressure when I was trying to determin airspring piston area. I came up with each spring having about 12sq/in of surface area. IE when I added #240 to the arch, I got a 10PSI increase in air pressure on the bag circuit. 240/10 = 24 sq-in/2 springs… if you t in a gauge to the bag side of the height valve you can measure the pressure easy enough…
