Camber/Alignment
Vapor Trail
261
Kentucky
I'm pretty concerned about the positive camber problem for alignments. I want/need to lift mine about three inches. The tires I have are 800 each so I won't be driving around with it unless it's perfect. I find it hard to believe that taking one 1/8" thick shim out will bring it correct. Does anyone have any input and what happens if all the shims are out and it still needs more?
Coug
4,147
Olympia/WA
The typical advice for lifts is to lift the body, not the suspension.
Lifting the suspension puts halfshafts/CV joints at extreme angles and wears them out much faster.
As far as I know if all the shims are removed and it still needs more, there isn't a whole lot you can do. Doing a suspension lift is well outside what the geometry of the suspension was designed for, so you're on your own.
Vapor Trail
261
Kentucky
I've done a 1.5" body lift and I need about 1 to 1.5 more inches with springs or spacers which I don't think it extreme. Lots of people run springs and spacers that get them 1 to 2 inches successfully. Even the unmodified vehicles have this camber issue. What happens when there's no more adjustment?
rcamacho
818
Bainbridge Island Wa
Custom made adjustable upper A arms is the most typical aftermarket handling of this issue I’ve seen.
XHP has these for a modest fee
Prior comments on half shaft angularity stand.
If you want to correct both and lift you’re likely fabricating custom lowered diff mounts.
juanprado
2,760
Metairie/La (N'awlins)
Ouch, that is beyond my definition of modest :cool:
