can not locate stop light switch
simp5782
Feo, Fuerte y Formal
9,264
Mason, TN
Hook an air fitting to the switch once removed. Put power thru one side, see if it powers up the other side when air pressure is applied. Usually 10psi is crack.
19,118
can someone tell me where the stop light switch is located ,I lost my stop lights and have been looking through the tm's but have had no luck finding the location,and is there a way to test it. thanks. this is on a 1989 m932a2.
If you want the paper copy, I have the TM version of what, where, and how.
TM9-2320-272-24-1
Key is to search inside the TM's for "stoplight" (without the quotes)
CHIEFSONN
Thanks for your reply and video showing me where the stoplight /pressure switch is located along with the tools to remove and replace it. Wes you are very Knowledgeable. Thanks.
