Check your axle ubolts
dmetalmiki
2,026
London England
You are correct..Smoking IS bad for you..But..I don't see anything but muck n' stones in front of that truck...So..Exactly what 'fell off it'.
Expand the story/Warning.
jth3rd
30
elk city , oklahoma
So had a small shake around 55mph
Checked everything out and found no issues and assumed it was just unbalanced tire.
Well today went out for a smoke and saw over half of the passanger side front ubolt had split clean in half and feel out within the past day where its normally parked
In a quick pretrial I would probably overlook it
19,126
I am not sure.
Might have had to go change my shorts after I found that...
Wow!
Tow4
622
Orlando, FL
What a surprise. I do always look at springs, shackles, u-bolts, shocks, airbrake cans, hub seals, air lines, drive line, tires ect, etc, etc. So far the only problems I have found were a leaking hub seal on the M915A1 and a loose u-bolt on the front axle of my M35A2. Glad you found that before it caused a problem.
CMPPhil
374
Temple, NH
Hi
That was very nice of your truck to spit out broken U bolt where you would see it. So often they bury those loose bits where you won't see. Thanks for sharing.
Cheers Phil
