- 7,397
- 2,479
- 113
- Interlachen Fl.
Yea got that I could run both at the same time but my well at 240 and 30 amps eats up almost all my watts if I understand. The 240 has a plug installed buy the guy I bought it from. I installed the 30 amp 120 RV outlet for my RV . So two different outlets. The switch I bought will handle 60 amps but looks like it is not to be used to switch live power. That is ok because I have the 35 amp. main I can cut off first before switching from 120 to 240 from reading up on it. That or when I shut down the machine to move the unit back closer to the house to run the RV because my well is 100 feet from the house. Thanks.There's no problem at all with running 120v and 240v devices at the same time. You just don't want to exceed the rating of the generator, which is where the breaker comes in.
Are you planning to switch a single plug between 120v and 240v? If so, that could cause a bigger problem if someone comes along and flips the switch, sending 240v to the 120v devices...
