clutch problems after attempted tow in 5 ton wrecker
drjconley
merced, ca
I would appreciate any help with a possible diagnosis on my m62a2. I tried to help pull out a stuck 10 wheel dump truck today. I had to be towed away from the still stuck dump truck with a clutch that does not return to its prior position. The clutch pedal now sits one to two inches from the floor with little to no resistance. I hope it is something easy, but my quess is that I will be cracking open a tranny and replacing a piece of medal put in the tranny seventy years ago.
Any and all help is greatly appreciated,
Thank You,
Jim
GHall
San Antonio/TX
Possibly the pressure plate or throw out bearing? Mechanical clutch or hydraulic? Depending on that, it could be the linkage or slave cylinder.
1,168
Did you use the declutch lever at the rear?
Were you winching?
drjconley
merced, ca
Yes, I did use the declutch lever. If that is it I will feel like I won the lottery. I will post tomorrow what I found. Once, again thank you for your time and help.
Jim
drjconley
merced, ca
Thanks for the help. Yes, I forgot the rear clutch handle. I would like to claim rookie mistake, but I have had that truck for 6 years.
Thank You,
Jim
73m819
315
gainesville, ga.
Thank You,
Jim
I do not believe that there is WRECKER owner that has NOT done the same thing, only after a bit of PANIC and a LOT inappropriate words do they REALIZE the problum
