Conical Washers from the Pitman Arm
Seth_O
Sac CA
I spent my weekend doing new axle boots on my deuce. In total, six hours on the d-side boot alone. Three of those were spent trying to remove two of the conical washers from where the steering arm attaches to the knuckle. Ultimately I was able to get them out, but they were destroyed in the process.
Anyone know where I can find replacements? I cant find anything listed online. I must have had bad search terms, because no love at McMaster Carr either.
Any help is appreciated.
sandcobra164
287
Leesburg, GA
I can get some from a local MV scrap yard and I'd be more than happy to help. I'm curious to hear how the original ones got destroyed during removal. I've done this same job quite a few times while helping friends and I've yet to have this happen to me but I'm always open to hearing what could possibly get me in trouble. I usually remove the top plates on the steer axle with a sand filled mallet once I have the 4 nuts and washers removed. I've occasionally had to use a chisel and hammer strike between the top plate and the knuckle to get them to break free but it's never damaged the conical washers.
gringeltaube
Staff Member
2,363
Montevideo/Uruguay
.............. trying to remove two of the conical washers from where the steering arm attaches to the knuckle.
Did you see this thread - before trying...?
FWIW, they are also called "Drive Flange Wedge". Apparently Dorman makes, or has them.
If you wanted to order online, here is one possible source...
G.
Seth_O
Sac CA
Jakob - I'll take whatever you can spare. PM with how much you want for them and shipping, cheers bud.
Sandcobra - appreciate the offer, if I end up needing more than Jakob has I'll shoot you a note.
G - that was a good read, tks for posting up the link. I am no stranger to the cone washers and actually had worked through the same list of steps with no love. I think the steering arm was installed by the same depot that put my lug nuts on north of 300lbs. They took a big rig shop to remove.
Ultimately I think my mistake was completely removing the 2 that came out without issue. That left all the pressure on the remaining to so they wouldn't pop free. I had to get a chisel in and tap them sideways, then they screwed off just like a nut. They're pretty trashed.
Seth_O
Sac CA
Rusty - thanks for the nod that direction. Between what you posted up and the helpful additional details from Gringeltaube I was able to find them at my local Napa for $1.75 ea. A heck of a lot better than the $45/ea that they were listed for online! To be fair, I did also find them elsewhere online for $.70, and ordered enough to replace them all, but its a 1-4wk shipping time as they are not normally in stock. By the time I pay shipping on them, its the same price as the Napa parts.
For those interested these are Napa part number TWD AX1007.
Attributes:Height : 9/16"
Stud Size : 5/8"
Top Width : 1"
Brand Name : HDPlus
Thanks to the folks who chimed in and helped out on this one - I need the truck for a community service project this week, so hopefully now it will be back up and running in time!
gringeltaube
Staff Member
2,363
Montevideo/Uruguay
Wait a minute: why Ø 5/8"? All the studs I have seen so far are 9/16" in diameter.
I just checked the NAPA-site: you probably need the TWD AX1014.
What left me wondering is their specified height of only 3/8". From what I recall ours are taller than that.
Let me see if I can find any loose, to measure.
Update: I just measured a stock OEM part:
  • ID = 9/16"
  • OD, top = 1" (!)
  • OD, bottom = 9/16"+
  • Height = 11/16" (!)
So, at this point I can say that the ones found online - even if the ID was correct - they are NOT applicable to our steering arm!
Maybe the ones we need are out there somewhere, but this is certainly not a standard size.
Sorry Seth if I was a little too fast earlier-on, when I indicated that link to the ones from Dorman...:oops:
First, see if you could reverse your order/purchase somehow. Then try to get a pair of stock replacements and better apply all tricks and patience next time, before destroying them!
G.
Seth_O
Sac CA
The TWD AX1014 shows 3/8" height as well? Also mine (albeit deformed) measured ~.97" across the top - I figured they were 1" when new?
Part Number: TWD AX1014
Product Line: TW DISTRIBUTION
Attributes:Height : 3/8"
Stud Size : 9/16"
Top Width : 7/8"
If you have a loose one to measure that would be very helpful, mine are deformed and now I am not trusting my measurements off them......
Seth_O
Sac CA
Thanks G! I'll canx the orders I have out there - fortunately none of them are for very much $, and I'll keep up the hunt. I really, really appreciate your checking the measurements on the existing ones.
In the meantime, I am on the hunt for any good used ones.
Jakob - sent you a PM bud ;-)
