Correct (3) Color Camo Patterns
Steel Soldiers is supported by:
CES 3245th
Based on RAPCO paint color charts on their website are these the correct (3) color camo patterns for a 1983 U.S.M.C. M923A1 5-Ton truck?
Any help from the Bullpen would be greatly appreciated, and thank you in advance!
Dead pilot
If you are going to use the current 3 color with the 383 brown, then you should use the 383 green. The black would stay the same.
Sent from my SM-G975U using Tapatalk
MWMULES
-23
No CARC paint, it did not exist in 83 use started in 85. Most of the early Corps truck I have seen were just Green or 4 color MERC cammo. I am not a Marine truck expert, but truck pic's from 83, I see only green or MERC 2cents
1983 939 pic's
1987 pic
M813rc
-20
For clarification -
34052 "Marine Green" is the overall colour used prior to camouflage.
First camouflage applied in the post-34052 era was 4-colour MERDC, mid '70s (Winter Verdant was the most common scheme with the Marines)
Mid-1980s on, camo (unless it is 686 tan) would be the 383 used by all the services, with the same colours -
34094 Green
30051 Brown
911 Flat Black
Regardless of how your truck was painted from the factory in 1983 (likely MERDC, that's how our first M939 series trucks arrived), it would have been repainted in 383 later, in the mid to late '80s (and tan after that if it went to the sandbox).
The patterns are in manual TB 43-0209 in the Technical Manuals section.
Here's a link https://www.steelsoldiers.com/showthread.php?187621-camouflage-TB-complete
Cheers
PS - the M923 MWMules posted above is not an active Marine truck, it is someone's personally owned truck painted the way they wanted it. The markings are inaccurate. Holler if you need help with how USMC vehicles are marked.
MWMULES
-23
Good snag Rory, I should have caught it by the Radial tires as not being in 83, turns out Pic came from a civi auction. BTW when did the A1's start?
in-the-rain-rows-of-m923-5-ton-trucks-from-the-marines-5th-battalion-10th-marine-b1dfa8-1600.jpg
[h=1]In the rain, rows of M923 series 5-ton trucks from the Marines 5th Battalion 10th Marine Regiment on a Unit Deployment Program [UDP] to 3d Battalion 12th Marine Regiment, begin a convoy after arriving in Sendai Port to Ojojihara, Japan 2002[/h]
https://youtu.be/KDiF0JeSQsM
M813rc
-20
I don't have the answer to that Dave. By personal observation, I know the Marines were putting 14.00s on M809 and M939 (A0) series trucks mid to late 1980s, before the A1 started being delivered, but I don't know if that inspired the A1, or if it was already on the horizon. David Doyle, or someone with his kind of knowledge, is going to have to answer that.
We called the 14.00 trucks Big Foot.
An incidental bit of information - the Marines did not use the M939A2s, by that point they were looking at the MTVR instead.
I'd love to find one of those USMC license plates they used in Japan.
CES, glad to be of help
Cheers
Arny
I just came across this thread using the search function.
Really thought about a looong time of how I want my M923 repainted and came across the following picture.
Does anyone know what kind of camo this is? Looks something like MERDC but with only 3 colors and they also seem to look different from standard.
Cheers Arndt
juanprado
-4
36
I believe the 177s were part of the ABS retrofit program
I believe that is correct. After numerous fatalities and rollovers, abs was mwo with the change to radials.
I did see some ndt's on non abs trucks out of shelby in the m939 mass sales.
