CTIS and Arduino
Plasa
315
Italy
Hello all!
As announced, here a short and unprofessional video of my Arduino CTIS ECU. It's an example on how it works when pressure is too low, it works also when pressure is to high.
You can set 4 diffrent pressures depending your needs, and works with 4x4 and 6x6 trucks as well. You do not need to change anything on truck side, just plug in and hope there are not other faults in the entire system, like stuck pipes, non closing wheel valves, leaking blow out valves etc...
Christian
ramdough
1,728
Austin, Texas
Hello all!
Christian
Does this system detect the same faults as the original system, and let you know what they are?
Plasa
315
Italy
There are some error messages, like PCU sensor fault, leaking wheel valves (if there is a heavy leakage), but not more. The ECU do not read the speed sensor to warn if you are in overspeed with low pressure.
Christian
Third From Texas
6,338
Corpus Christi Texas
My controller is going tits-up. It's been acting up for some time.
Mine is an A1R with the C7 and all sorts of fun electrical bits. The controller is different than the A0 models (I'm told that they are totally incompatible). I'm not really interested in spending a grand on the correct OEM controller, and I've always said that I wanted to go Arduino when the time comes.
But the problem is: what exactly is the difference between the older A0 controllers and the later A1R controllers? And can it be negated via Arduino programming?
Awesomeness
1,511
Orlando, FL
I'm not sure if there is a separate A1R controller, but there are A0 (green) and A1 (black) controllers. The black ones are programmed differently (PSI), and did not work in my A0 (for whatever reason... it could have been bad, or just not liked the A0, but it just blinked "CTIS Overspeed" all the time).
Since the Arduino route is circumventing most of the original circuitry, it may still work.
Ronmar
6,711
Port angeles wa
Yea they all use the same PCU and sensor…. Now wether they assigned different wiring for that at the controller end of the harness may be an issue. They do have different dash harnesses in the different trucks…
Ned81
180
VA
I ordered an Arduino controller from Plasa. It’s in transit right now. It’s completely customizable on the fly. He has been building them and updating them for a while.
Plasa
315
Italy
What I know (and I do not know much) is that from A1 (the black ECU) speed signal is not a digital signal, but on CAN BUS. This can explain why overspeed warning do not work. The entire ctis is from dana/spicer, I don't think they changed the wiring, if it's always the same round connection...
Solenoids and pressure sensor / transducer are the same. But I can immagine that if the speed signal is not correct, the OEM ECU will not work to prevent damages.
Christian
Russ Knight
1,051
Perry, FL
I am interested in a controller that will control the front and rear axles separately, using a set point, instead of selectable pre-sets.
Plasa
315
Italy
Right, you have to split the entire CTIS system in 2 parts, front and rear. No ECU for now will handle that, except if you add a intermediary valve and switch from front to back manually. So PCU and ECU do not know that only 1 axle is measured. But you can't set 2 diffrent pressures, so you have to change ECU anyway.
Christian
You would need a different PCU or another set of intermediary solenoid valves to divide up the system into front and rear sections…
