CTIS LEAK 931a2
M35A2-AZ
382
Tonopah, AZ
I would check the hose from the valve to valve stem housing, check valve stem, also the O-ring in the wheel.
roalcoal
poplarville ms
I had the same problem on one of my back tires. When I started checking the hoses I found a lot of the joints were loose from the axle to the tire
Coffey1
493
Gray Court SC
Andy's front left tire would leak down also .
It turned out it was the block on backside of rim.
The tire will have to be broke down to tighten it.
tractors0130
Joliet, Illinois
Remove the CTIS temporarily from that wheel and screw a schrader valve inside the valve stem and see if the tire still goes down.
If it still goes down, soap around the studs holding the wheel together while the tire is laying down, you might see bubbles there indicating an o-ring leak and double check valve stem block on the back of rim like Coffey1 mentioned also.
Not too bad of a job to unbolt the rim halves after the tire is deflated and replace o-ring or take it to a tire shop and let them do the whole job.
Make sure that you have a new o-ring in hand before you start, more than likely the tire shop won't have one unless they work on Military truck tires.
wreckerman893
Possum Connoisseur
15,612
1,984
Any tire shop that does skidder tires or other big ag type tires should have o-rings that will fit.
todds112
Teton Valley, ID
I'm currently battling leaks and so far it's the O-Ring and or the turret valve grommet on the rim. I will also replace the little oring where the CTIS hose connects to the valve stem. Looks like someone just kept tightening it down hoping to fix a leak and shredded them.
Andyrv6av8r
453
Spartanburg,SC
Anyone know the part number for that little o-ring under the wheel valves? I looked through the TM's but I'm still not sure if I have the correct one. I'm thinking it is 1/8 thick X 3/8 I.D.
1 Patriot-of-many
Zimmerman MN
Local hardware store should have them or a reasonable facsimile. Where I got one of mine.
