CUCV Radiator Replacement part
Warthog
227
OKC, OK
Search 2098 in the CUCV forum. Hundreds of threads about the radiators. Some use copper, some use aluminum. Both work. Just depends on how much $$$ you want to spends. I wouldn't go used as most are corroded. Rebuild is always an option.
MarcusOReallyus
811
Virginia
The search function on this site leaves a little to be desired. *ahem* (Okay, it's almost useless.)
Best way to find something is to use a search engine that allows you to search on a particular site.
If you don't mind Google peering into every orifice of your online life, and selling that information to every Tom, Dick, and Harry that wants it, you can do that with Google.
If you prefer a little privacy, try DuckDuckGo.com. Search results are comparable to google, but they don't track you.
Here's what it looks like:
https://duckduckgo.com/?q=+aluminum++radiator+site:steelsoldiers.com
Notice that I put a PLUS sign in front of each search term? +aluminum +radiator That tells duckduckgo that I want BOTH of those terms, not just EITHER of those terms. That way I don't get hits on aluminum brackets or radiator corrosion or other stuff I don't really want. I'll get only results that contain "aluminum radiator".
Next, the site:steelsoldiers.com forces it to search only this site.
The syntax is the same for google.
Have fun! :beer:
