Deuce Cold Weather Upgrades
markmontana
Mesquite, NV/Layton, UT
My latest solution to cold weather gear for the deuce: a radiator cover. Required materials- one piece of scrap cardboard out of the neighbors trash and a couple zip ties. A few minutes on the calculator and I came up with the correct free flow area to leave open in the center.
I can report that it is still there and working after a few weeks of driving in both rain and snow. The increase in temp is about 20 degrees in 25 degree weather. That's a big difference and worth all the expense of this upgrade (about 6 cents so far).
Stay tuned for upgrade #2...
Jake0147
Panton, VT
If you slide that cardboard behind the grille from the bottom, you can "hook" it in there and it'll stay just fine... Couldda saved saved those zip ties... :p
markmontana
Ha- I forgot to mention that it was dark out, 15 degrees and I was in shorts and flip flops- so no way was I going to that much trouble...:-D
But your idea is now on my list
