Deuce muffler option
ShawnIfert
chatham PA
Here is a pic of the m35a3 intake installed. Just remove the old intake filter housing and cut the access door shorter. Buy adapters, elbow, 45, some clamps and a piece of aluminum pipe.
ShawnIfert
chatham PA
A lot more CFM of air is the main thing. It moves the filter housing from the engine bay and gives you more room to work on the engine. It make less noise because of it location outside of the engine bay. It takes in air about two feet higher than the stock cleaner and has turbulators to drop the dust from the air and has a purge system when used with the a3 muffler. It is easy to install, almost bolt on.
Wildchild467
56
Milford / Michigan
How much air does it flow?
yolner
68
Rockville, MD
Cool. One more thing to add to my upgrade list!
ShawnIfert
chatham PA
If you have any questions about my mods or on the m35a2 just ask. I have rebuilt mine from front to back down to the wiring and of the wiring is new. I have put a dump hoist kit in it, Stereo with a 400 watt amp and so on. We are here to share info!!
rustystud
2,389
Woodinville, Washington
so have you did the mod with the exhaust?
I haven't finished the exhaust part yet. I just have a cap on the filter housing for now. To many projects going on, and too old to finish them all !
Truth be told, I forgot about finishing the exhaust clean-out part of the filter. Now that my shop is almost finished I should fab-up a tube and weld it to the muffler.
ShawnIfert
chatham PA
Cool. I just wanted others to know. It is a simple mod with available parts. It looks good and it is clean. Most just scab some crap on there and it looks like crap.
ShawnIfert
chatham PA
Information is hard to find on this site, you really need to look. But we are here to help the young guys more forward and do it correctly.
I do thank you for your help in the past. This is a team effort. I am still working on my truck too. LOL
My brother calls it the brand new 1971 M35A2. lol
I did convert my engine to a LDS. But my trucks engine was put in new in 1989 so it is the best one. I have a post on how i did the mods. It is not cheap. I should put a 5.9 in it.LOL
rustystud
2,389
If I had the money, I would put a DuraMax L5P with Allison transmission in mine. 500 HP with almost 500 Ibs of torque would make my Deuce sit-up and dance !
Last time I checked though a DuraMax LML (not a L5P) cost over $8,000.00 used !
