Deuce Parts Quick Reference Spreadsheet
hawkeyepoole
Keller, TX
:idea:Alternator Belt alternative possiblities!!!!2cents:idea:
On my 1978 AMG Deuce, the alternator was virtually laying flat on the primary fuel filter with the recommended alternator belts. I bought a set of 9465 belts which are 46 7/8", or one inch shorter than the stock size listed in the spreadsheet here. They were perfect on my truck. Short enough to get the alternator off the fuel filter so I can get a wrench down there, but long enough that I can push the alternator up far enough to get the belts on and off.:idea:
ARYankee
31
Benton, AR
Awesome resource. Thanks for the hard work you put into that. Now only if we had one for M809 series and the M939 series.
Here are a couple of threads you may want to check out:
https://www.steelsoldiers.com/showthread.php?82404-5-ton-parts-quick-reference-spreadsheet.html
https://www.steelsoldiers.com/showthread.php?81416-m939a0-m939a1-pmcs-parts-supplies.html
https://www.steelsoldiers.com/showthread.php?83631-5-ton-parts-database.html
The last thread..... I'm still working on the database and will update it when I am done.
Ford Mechanic
Edenton, NC
Great spread sheet! What about adding fluid types and civilan equivilants for some of us new folks that don't have Military experiance? Example: GAA = ? Multi purpose brake disc and wheel bearing grease, the red type?
Brake fluid type? DOT 3,4, or 5?
Engine oil wieght? 15w40?
80/90 = 80w90 is the same right?
HDO 30 = ISO 46 or ISO 68?
CW11C= air tool oil, wd-40?
I'm going thru the Lube order TM trying to figure out what works for what.
Thanks for the info.
Ford Mechanic
Edenton, NC
Several of these NAPA #'s my local store is telling me they don't work?
Filter o-ring 15211
Master cyl. Fed./Mog. FE3527
Wheel cyl. up4419
Wheel cyl. reb kit UP45
Any help please as to why?
VPed
287
Clint, TX
Ford Mechanic - I used the UP45 number at my local NAPA just last week. Worked fine for me.
Vick
