- 190
- 63
- 28
- Austin, TX
I know the military prefers over to have over 2,000 CCA available with their battery set up but I'm curious if there is any Cummins documentation on cranking amps needed for the M939 series. The reason is I'm looking at a getting a couple new Group 31 batteries and will need to determine if I go with the higher CCA (950-1000) or the lower (750-800) from the same family. Reserve is effectively the same on both (190 vs. 170) so just wondering about needed CCA. The reason I'd like to go with the lower CCA is I understand the plates are thicker in the lower CCA and generally last longer in rough riding vehicles. But to the point, I know I CAN crank my NHC250 with 2 group 65's at 700 CCA as I've done it many times but not sure I want to put that much strain on the starter if I'm on the edge of cranking requirements. I just haven't seen any literature (not folklore) on what is required for our trucks.
