Doghead relay...oops
DokWatson
Wasilla, Alaska
I didn't realize I didn't need the relay since I have a 12 volt truck. I was wondering why it wasn't working... since I've already come this far, can I still wire it to work? Or have I really messed up...
Warthog
227
OKC, OK
If it had the stock relay and was working, changing it out with the new relay shouldn't change anything.
How was your truck converted? Using the Roscommon method? Pictures?
DokWatson
Wasilla, Alaska
The stock relay stopped working this morning, thats why I decided to do the relay mod. I didn't know the relay wasn't necessary, now I'm not sure what to do. I didn't do the conversion. I am fairly certain it is the roscommon conversion.
Warthog
227
OKC, OK
All depends on how the Previous Owner converted it.
Since the old relay is still in place, we will assume it is still used and you will need to install the doghead conversion.
You will still be using 12v to energize the relay and just switching 12v instead of 24v.
Here is the Roscommon conversion and the stock starting diagram
DokWatson
Wasilla, Alaska
Haha, I figured it out. Dogheads mod was not at fault, it was the battery connection to the junction block. It must have loosened when I disconnected my batteries. Oops.
Warthog
227
OKC, OK
What do you mean. Doghead is always at fault!!!
Glad you figured it out.
DokWatson
Wasilla, Alaska
Good mod, I like the louder click to let me know the starter is getting power. I know people had trouble with finding the part at napa. The part number is more specifically SME7018601, and comes in a plastic bag. Took a minute for the employee to find it, he was looking for a box with the part number not a bag.
Store Locator | NAPA Online
1,168
Notice the dashes in the part number, both on the bag and on the bill.
If you need to tell them what the package looks like, you might be in trouble.
I wish people would stop posting new threads with DOGHEAD RELAY in the title, it just adds to the jumble of search results.
chevymike
453
San Diego, CA
I actually bought the O'riellys one but haven't installed it yet. Looks to be the same as the NAPA one.
Even if doing a 12 volt conversion, the advantage of keeping the relay is that it takes the switching load of the starter solenoid off the ignition switch, which is known to be a weak point in many older GM vehicles. With the relay, the ignition switch is only turning on the relay, which in turn handles the main load of the starter solenoid. Is it needed for a 12 volt conversion? No but it's a great thing to have in place.
