- 4,223
- 2,907
- 113
- Fort Worth, Texas
I've followed the TM and dug into the dash to identify this problem but no success yet. All electrical instrument gauges do no work with the exception of the high beam indicator and no charge light which are controlled by the power/ignition switch. The start relay under the hood had the starter button spliced in to start the unit without dash power but the original harness is still in place. This unit was overhauled in 10' with no signs of rat damage (thank god). I've pulled the dash and traced proper voltage from the battery -> battery disconnect -> power/ignition switch -> combination instrument cluster but no life from any electrical gauge. I do have power to the center indicator lights on the dash above the tach.
I came across The FLU farm's thread about a hidden relay on the alternator that could cause issues but I have confirmed power to the gauge already. Any thoughts?
Reference:
https://www.steelsoldiers.com/showthread.php?173645-New-FLU419-Owner-Electrical-Woes
Reference:
